App and Broadband
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎13-12-2021 08:16 AM
My broadband is having rolling outages. At a time where we're being asked to work from home this couldnt be worse timing. Tried to log into the My EE app this morning and can't log in there either?! What's going on? I need my broadband to be stable.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎13-12-2021 10:27 AM
Hi @Evolved_ape,
What problems are you experiencing with your home broadband? Is your WiFi dropping out or do the lights on your router indicate a complete loss of connection to the internet?
Which error message do you see when logging in to My EE?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
‎13-12-2021 02:23 PM
- For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
- For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
