close
Adding a second EE smart hub router
Wiligee
Io bought a 2nd EE smart hub router on eBay which has a different network key and password to my other EE smart hub router. Is there anyway to set it up as a second access point? So I can better better internet connection at the back of my flat, as having a lot of congestion issues with my WiFi as certain times of day
Christopher_G
Hi @Wiligee
Welcome to the community.
I recommend speaking to our Tech Gurus to see if they can help you with this. Unless @XRaySpeX can help?
Only if you are able to mimic To make a second Brightbox as a WAP on your LAN to the main Brightbox
How do you mimic it?
