4g lte internet settings on nokia
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 12:04 PM
Hi, I am swapping a business phone from iphone to a classic Nokia 800 tough as i want some battery power to take calls ! which is the reason for having the phone in the first place. lol
This Nokia has 4g access but its not working, I phoned EE support and they said this phone is not supported and gave me some APN settings, I entered them and the 4g symbol appeared but still no 4g data (i only really want it for the map function)
does anyone know the correct nokia KaiOs apn setting to enter as i must be doing something wrong
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 02:28 PM
Here seem to be known-good settings: https://apn-uk.gishan.net/en/apn/ee/nokia-800-tough
Surprisingly no mention of identifier.
Curious the device is not listed at https://setup-ee.wdsglobal.com/internet?step=manufacturerselection.vm&contractId=230&countryId=36&ne...
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 12:50 PM
Hi @Marshmill77 ,
I assume you've restarted a few times.
Are you able to check in your settings whether you device has received an IP address along the lines of 100.x.x.x or 10.x.x.x ?
If your device successfully receives an IP address, the next thing to check is whether domain names can successfully be resolved. Another person might be able to provide an IP for ee.co.uk or bbc.co.uk for this to be checked (not easy for me to get on a mobile).
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 01:06 PM
Hi Yes restarted several times, there is no way to check the ip from the settings menu.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 01:22 PM - edited 26-06-2021 01:25 PM
Your Nokia is 4G assuming it's a EU or Global version, you shouldn't need any special settings as long as the APN is set correctly for 2.5 / 3 / 4G.
Is it working on 3G ? Is it Dual SIM, 3G will probably work together on both Sims but 4G on only one of the Sims.
If it's a Dual SIM make sure your SIM is in SIM Slot 1 of 2(or 0) and that the Mobile Data is switch on for the same SIM slot that your using.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 01:35 PM
not working on 3g either, but dont think data has ever worked on any phone i have had on 3g, only when connects to 4g in the past,
It is duel sim (furthest slot in the tray), but only offers setting for one in the menu (no mention of a second sim slot in menu)
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 01:56 PM - edited 26-06-2021 01:57 PM
If it's Dual SIM it's probably a shared Slot ie, SD Card or SIM, so either put a second SIM in or a SD Card, the SIM tray should be marked 0 & 1 or 1 & 2, but as a general rule the SIM that shares the SD Card Slot is normally SIM 2.
What's the current APN settings (Full details)
SIM Slot settings will probably be something like -
Settings/Connectivity/DualSim/MobileData/etc but may not kick in without a second SIM in.
APN will probably be as above but then -
..../MobileData/AccessPoints or APN
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 02:03 PM
Correct APN Settings
APN: everywhere
Username: eesecure
Password: secure
Address Type: IPV4
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 02:11 PM
Hi, sorry had assumed it was duel sim but from closer inspection of slot you right, it single sim with a SD card next to it.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 02:16 PM - edited 26-06-2021 02:20 PM
The phone came with no apn setting or it hasnt created any after putting the sim in, i have deleated the one i put in and re-entered following your spec, only difference is that there is no slot for username, only identifer ?
Still no connection to 4g (even though its showing it on the screen),
interestingly when i go into my business login on here, under my number the phone is not identified either.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2021 02:21 PM
Not sure what identifyer is, cloud be the Name. Is what do you want to call it, play safe , put "everywhere" in both the identiter and APN Name or any field that asked for a name.
- Lost smart WiFi option on EE home app in Archived Posts
- Issues with EE SIM in Tenda WiFi Router in Archived Posts
- EE access controls, group empties after any reboot in Archived Posts
- BT to EE Broadband migration - own router - suspiciously easy :) in Archived Posts
- Unable to connect to Router in Archived Posts
