close
Forgot password
FLASHRED99
My 4gee dongle I can’t remember the password
Leanne_T
Hi there @FLASHRED99
If you visit http://192.168.1.1 on another device connected to the WiFi router, then enter the username as 'admin' and the password as 'admin' so you see the password?
Thanks 🙂
Which pwd have you forgot? The admin pwd or the WiFi pwd? Have you looked at the label on it or under the battery cover?
EssexBoyEE
Assuming it's a Dongle, as in a LTE / 4G USB Dongle then it probably won't have a WiFi Password as it will connect directly to the Laptop or PC, so as @Leanne_T suggests access the Admin Page via 192.168.1.1, if that doesn't bring up the Admin Page / Dash Board then there may be some software on the Dongle to Install Dash Board Software to the PC (Normally on the D Drive of the Dongle).
Other option it could be a WiFi Dongle talking to a 4G Router.
