close
4GEE WiFi invalid SIM
PhilDuignan
It's been a while since I used my PAYG 4GEE mifi device. Logging in now it tells me my SIM is invalid. Do I need a new SIM or is there a way of topping this one up?
Leanne_T
Hi @PhilDuignan
When was the last time you used the SIM, was this over 273 days ago?
Speak soon 🙂
Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
It may have been close to a year now that I think of it.. guess I need a new SIM? Can you link me to some options I can get delivered in a hurry?Thanks so much!PhilSent from Samsung Mobile on O2
See PAYG Data SIM
