close
4G not working
drylipss
I am a new user.
Yesterday, the '50 MB Initial Allowance' can be used and ran out. But today, the 'Pack Allowance 8 GB ' cannot be used.
And, the call function is available, and text function is half available. I only can get message, but cannot send them out.
I try to a lot of way to fix this problem. Anyone can do a favour?
18 REPLIES 18
James_B
EE Community Manager
Hi @drylipss,
What happens when you try to open a web page in your browser over mobile data?
“could not activate mobile date network, PDP authentication failure”
James_B
Hi @drylipss,
What type of phone are you using?
iPhone 8
James_B
Hi @drylipss,
If you go to Settings > General > About, are there any carrier updates available?
Settings already show network provider EE. Does it have anything to do with my phone's type?
James_B
Did you see an option to update your carrier settings @drylipss?
unfortunately, I could not see that. I put SIM card into another iPhone, it's shows not network too
Christopher_G
Hi @drylipss
If you're still having problems, I'd definitely recommend speaking to our Tech Gurus so that they can look into this further.
