messages does not work
aia1510
hello! for some reason, i cannot send messages or receive messages BUT it also takes my credit still, which i find VERY annoying. how do i fix both issues?
Northerner
Hi @aia1510
What device do you have and did you get it from EE.
I assume you're on PAYG. Have you tried restarting your device?
I use the iphone 8+ and it was EE locked. i have used an EE sim card for
years now, and i’ve not had issues with it, but now i do. i’ve restarted
the phone but no solutions
Jon_K
Former EE Employee
Hi @ala1510.
Are you able to make and receive calls on the phone?
Is this happening with more than one number?
Jon
Hi @aia1510
Can you access the internet?
iMessage uses data as it connects to the internet. Try deactivating iMessage and text message will go via EE. If that works then it's iMessage/data which is the issue.
