How to quickly get to Recordings?
Jambotart
In EE TV to get to My Recordings I go to Home Screen, then move one click left, then four clicks down to My TV then OK.      There must be an easier way - can anyone help?   And for clarity, if I go to Home Screen then click two down I only see some recordings mixed up with watch-list items.
zulu17
Star Contributor
Star Contributor
Your path to your recordings is dictated by the current EETV  home page and how EETV  display MYTV pages
So your current route is
 go to Home Screen, then move one click left, then three clicks down to My TV then OK
(As the one click left from Home takes you to the second position  (Home) on the sidebar a further three  clicks down takes you to My TV and then you select it.)
Alternatively press guide button on remote then back button two clicks down to My Tv then OK
Yes I know.  That’s what I already posted.  The question was- is there a quicker way, for example programming one of the colour buttons to jump directly to My Recordings?    The current setup is worse than the old one.
