01-10-2026 12:51 PM
At present the EETV app provides the the functionality to schedule their Youview box recordings remotely without having an EETV subscription.
Ie the functionality that the YouView own app used to provide. Will this continue post 15 October ?
01-10-2026 12:56 PM
Yes, this will continue to be available in the EE TV app, and also be offered in the BT TV app. The only change is that it's no-longer anonymous, as both apps require you to log in (but a BT ID or EE ID can be created without a subscription on it).
For those with more than one recordable box, you'll be able to use one app for each, if you so choose.
01-10-2026 12:56 PM
