Ee tv box remote
Jhced
Can anyone tell me where you find the tv codes trying to pair remote with sky glass
DarrenDev
EE Product Expert
There are no codes for the new EE TV remotes - the remote will automatically pair with the TV that the TV Box is connected to. If it doesn't pair, it's not supported.
DarrenDev
EE Product Expert
Argh right yeah not allowing me to adjust volume and turn tv off, there was instructions online about holding 9 & home then doing a code from the tv list
DarrenDev
EE Product Expert
Home and 9 resets the remote, so that it queries the TV again.  There's no option to enter a code from a TV list - that was only possible with the old IR remotes.
Jhced
Right okay thank you. Is the flashing purple light still a thing aswell cause mines doesn't do that
DarrenDev
EE Product Expert
Yes, the light should still flash when it has reset.
