TV Box Pro
colin148
How do you skip intros and recaps on the TV BOX Pro as the remote doesn't have the symbol it tells you to use to skip?
DarrenDev
EE Product Expert
If it doesn't show a button on screen to skip it, then it means the app you're using doesn't offer that feature.  Some apps allow you to press left and right to skip forwards/back, whilst others need you to use the fast forward and rewind keys.
DarrenDev
EE Product Expert
