Change netflix account
RobMU69
Valued Contributor
Valued Contributor
Sorry but I can't seem to get a definitive answer to this.
I have a Netflix account linked to EE for billing. What I would like to do is change to a different Netflix account also in my name but with a different email address. Any one any idea how I achieve this please?
Alex_H
Hi @RobMU69,
You can change  the email address you use to login to Netflix by logging into Netflix and going to Account> Security> Email> Change Email.
However if you already have an existing Netflix account on the email address you want to change to, it wont be possible to change it that way.
You would need to first use the transfer profile option to move the profiles from the other Netflix to your current one, then delete the account on the email you want to use so that you can then change the login email of your current account using the above steps.
Alex
Alex_H
Hi @RobMU69,
Alex
RobMU69
Valued Contributor
Valued Contributor
Thank you @Alex_H
That's very helpful.
