17-02-2025 02:01 PM
Hi hope someone can help me with this. I've had the EE tv system for months without any issues, yesterday I went to turn the main box on in the living room and it had gone to the let's get started page instead of the home page. I attempted to navigate off this but the screen is frozen and won't respond. I have tried disconnecting everything for a length of time but still just get this frozen page. My bedroom mini box is still working. Can anyone out there advise ?
17-02-2025 04:18 PM
Hey @lestone5209, thanks for getting in touch via the Community 😊
How long have you left this stuck on this screen for?
Also have you had a chance to check out our help pages to see if any of these troubleshooting steps help?
Peter
22-08-2026 09:11 PM
How did you get this sorted mines is doing the same, stuck on the home screen, tried a reset,tried leaving it off for few hours but nothing helps
23-08-2026 09:56 AM
Hi @Fergalkerlin,
Welcome to the EE Community
If you have fully reset your TV Box Pro and you are still having the issue, please reach out to our TV technical team for further assistance.
-Alex
23-08-2026 09:59 AM
One thing to check first - if you've reset your box then you also need to reset the remote, as it'll no longer be paired with it. This would have the same symptoms as the box being frozen - i.e. nothing happens when you press buttons.
https://ee.co.uk/help/tv-sport/fix-problem/reset-your-ee-tv-remote-control
