BT YouView Box
Kevin1511
I have a BT YouView box (part of the EE deal years ago).  I understand it's no longer supported (from last February I believe).  Some apps such as Prime video and my5 etc aren't working.  Can I order a new EE TV box?
zulu17
Problem solver
Problem solver
Hi @Kevin1511  Only the First generation T1000 series BT Youview  are no longer supported  by the Youview  platform.
If you had a current  EETV subscription or service then you should have been sent/offered a second generation  box when the T1000 service was withdrawn. If you still have a current EETV service contact BT or EE to enquire  about a box upgrade. This assumes that you have not previously  had a replacement  box issued.
zulu17
Problem solver
Problem solver
