Recorded programmes are sorted old to new - can it be changed to new to old?
robws
Hi, on my EE TV Box Pro, when I go to My TV, each recorded programme/series is sorted newest first, but when I select a series to pick an episode to watch, the episodes are sorted old to new, so if there are a lot of them, you have to scroll a long way to get to the newest episode. Does anyone know if this can be changed so that it's newest first? Thanks.
-Luke-
No there isn't a method to have them displayed in reverse but there is an easier and  quicker method then scrolling through the episodes.
This has previously been raised.  Not everyone wants what you have requested and rather than complicate the settings, or change it so that others who like it as it is are then frustrated,  a method was added to easily skip to the newest using just 1 button tap on the remote.
Next time you you are viewing a row, and want to skip to the far right, just tap the fast forward button on your remote once.  It's a lot quicker and easier than scrolling.
Should you ever want to get back to the start of the row, use a single tap of the rewind button.
This jumping to the far left or right of the row also works with the shortcut rows on the home page.
-Luke-
