Apple TV trial not working
Badger1025
Hi
Like many others I'm really struggling to activate the 6 month free Apple TV subscription.  I have the add on live on my account, however the link  I was sent via 150 does not work, just goes straight to apple tv home page with the offer of a free 7 day trial. I've had two lengthy calls with EE now, one suggesting I openened the link over mobile data (doesn't work) and another where I was just fobbed off and never heard back. Not sure why something so seemingly simple is proving complicated with zero support on offer from EE. Does anyone have any suggestions how to fix this?
Thanks!
Badger1025
Hi, finally got a solution for this (thanks to Michele ***** in tech support team!). Issue for me (on a Samsung s21) is that my sim card was attached to a different number than the one I actually use - this only became apparent looking at 'about phone' in settings. To change this to my actual number I had to look up myself in contacts, add my actual number and then set this as default. Then when clicking on the apple link it Sent me to the 6 month EE apple tv trial page instead of the standard apple home page. Hope that might work for other people with the same issue
[mod edit: employee details removed from the public forum]
67 REPLIES 67
DarrenDev
EE Product Expert
I assume you're using Safari on your iPhone or iPad? Have you tried a different browser? Or from a different device? I can't remember the exact details at the moment, but I know Safari was causing issues for this.
Hi
No I'm using a Samsung phone. Does this only work on apple devices?
James_B
EE Community Manager
Hi @Badger1025,
You should still be able to activate this offer on an Android phone as long as you haven't used this particular offer before.
Have you been able to try a different browser?
Hi
Thanks, but using a different browser makes no difference either - link goes straight to the standard apple tv home page
James_B
Have you had an Apple TV+ trial through your EE account before, @Badger1025?
Hi there, no I haven't
Christopher_G
OK, thanks @Badger1025
If you speak to our Mobile Care team, they'll do their best to help you get this set up.
Jaxun
I have the same issue on my samsung
Boomooboo
I have the same issue. The link sent via text only takes you to the Apple TV homepage and did nothing more.
