24-05-2026 03:00 PM - edited 24-05-2026 03:01 PM
Hi everyone, my Moes smart home gateway stopped working overnight and after extensive diagnostics I've identified that EE's network is blocking the Moes/Tuya cloud servers.
The blocked IPs are:
These are AWS Frankfurt servers used by the Moes/Tuya platform for both API and MQTT connections.
What I've already tried:
Has anyone else experienced this? Is EE filtering these IPs and how did you resolve it?
on 24-05-2026 04:55 PM
@gmanochio what makes you think that it is EE blocking things?
If you have tried a either that should eliminate the EE gateways if you have set it up properly.VPN and it does not work on that
