help needed to activate simcard
At19-
 I have been sent a new sim card but it will not work.
77 REPLIES 77
Was sent out with the new phone assumed I had to use that one rather than transfer the old one over as was sent a PIN and PAC code with it
James_B
EE Community Manager
Hi @KLM79,
You only need to use the new SIM if the old one doesn't fit your new phone. Have you tried putting the old SIM in your new phone?
no
upgrade
Katie_J
Hi @Mickysue222.
Please try use your old SIM in your new device and let us know if you experience any problems.
Katie 🙂
My sim card is old so I got a new card
James_B
Hi @Awarapagal,
Click here to activate your SIM online.
Hope this helps.
charliebeech
I got a new sim in store today after I lost my phone however the online portal only gives me the below option
You'll need your device with your old SIM or eSIM in it to receive the PIN
I so have a PIN and PUK on the sheet with a replacement sim but i cant find the correct portal to activate
Leanne_T
Hi @charliebeech
You would need to call us to activate the SIM if you don't have the old SIM card, you can call us on 0800 079 8586.
Leanne 🙂
Ramraj23
Hi dear
