12-08-2024 10:12 AM
i resest wifi on my mobile, now it wont accept the puk code after restarting
12-08-2024 12:31 PM
Good afternoon @cjillsley.
Welcome to the EE Community 😊
Just to be sure here, am I right in thinking that it's a network settings reset you've done here, and this has locked the SIM so it's asking for a PUK code?
What model of phone is it you're using at the moment, and where was it you got the PUK from?
Peter
12-08-2024 01:26 PM
12-08-2024 01:34 PM
I'm really glad to hear that's all unlocked for you now @cjillsley
Definitely an odd one with your WiFi though.
Will these apps work fine over mobile data, and have you checked to make sure your software is all up to date?
Peter
12-08-2024 01:39 PM
12-08-2024 02:10 PM
Cheers for checking that, @cjillsley.
Is your software all up to date at the moment too?
Also who is your broadband provider, and have you tried loading these apps on a different device?
Peter
12-08-2024 04:04 PM
12-08-2024 04:09 PM
Thanks for giving all of that a shot @cjillsley.
Are other devices on your WiFi still able to access these sites okay?
I know on mobile our strictest content lock setting blocks social media, so my thought was that there could be a parental control setting out of line somewhere here.
Peter
12-08-2024 04:13 PM
12-08-2024 04:36 PM
That's no problem, was worth checking just in case @cjillsley.
If everything is good with your data, I'm definitely thinking this is the handset.
A few users have reported similar via Samsung's Community and I've found a thread on it that could be worth checking out 😊
If you have no success there it could be worth checking in with your broadband provider too.
Peter
