Stuck in USA ee are rubbish!
Dan516
I am stuck in the USA and can’t make calls to ee and need to urgently. There is no way to contact ee.
an awful provider cutting corners again.
What can I do?
35 REPLIES 35
@Dan516  So instead of just answering the question and it seems you are not going to best of luck in trying to get this resolved.
Rach_H
Hi @Dan516,
Did you have your eSIM set up before you left the UK? If you have a SIM showing as 00000000 then you should be able to delete this SIM, as it may well be interfering with your connection.
Rach
Hi chris, I did request you not to respond.
If you don’t have anything nice or kind, I’d appreciate it if you could
just stay out. I don’t think this is a positive interaction for either of
us.
[Mod edit: Removed company information]
Hi rach, I was advised to remove the physical sim - do you think that will
work?
Rach_H
You can try removing the physical SIM @Dan516 but if you have tried to activate the eSIM while you are away then that may be why you're having trouble.
When was it you set up the eSIM?
Rach
