Roaming not activated in Grenada
Davesargent
Neither of my mobiles will connect to the local networks in Grenada. I only need voice and SMS not data H. I can't call customer services because I don't have a working phone.  How do I get it turned on?
Schockwave
Hello @Davesargent ,
Welcome to the community,
Did you receive the welcome message from EE?
If you did not and are on contract, did you enable roaming on your devices before going abroad?
Have you used your SIM card in the UK before travelling abroad?
Are you on contract or pay as you go?
Ways to contact EE, see my signature.
Whether or not you need data is immaterial - you need a mobile network connection to use any one of calls, texts or data.
Use the advice already posted to get international roaming enabled on your SIM.
