sms
Elyas6740
    Hi, I’m currently in Iran using an EE SIM card.
    When I first inserted the SIM into my phone, I received the welcome SMS from EE. I have also activated the SIM through the EE website, and I receive all SMS messages sent by EE without any problems.
    However, I am not receiving any verification SMS codes from either Telegram or WhatsApp.
    Could you please check whether there is any issue with receiving verification/OTP SMS messages on my EE number while roaming in Iran?
    Thank you.
Ali_A
@Elyas6740
All EE SIMs must be first used in UK before they will fully unlock to work abroad.
There is no way to remotely unlock this. The only option you have is to send the SIM back to the UK to make the first phone call and then send it back to Iran.
This is the same for all countries outside of the UK.
Ali
11 REPLIES 11
Elyas6740
Hi EE Support, I’m currently in Iran using an EE SIM. When I inserted the SIM for the first time, I received the EE Welcome SMS, and I can receive all SMS messages sent by EE without any issues. My number is correctly linked to my My EE account. However, I do not receive any SMS from other senders, including verification codes (OTP) from Telegram and WhatsApp. Could you please check if my line is fully provisioned for receiving SMS while roaming, and whether there is any issue with my SMS provisioning or roaming profile that needs to be refreshed or reset? Thank you.
@Elyas6740 : This public user discussion forum can have no access to your specific account & so cannot check anything to do with it. You need to raise this with CS.
Thank you. I understand that the public forum cannot access my account. Is there any way to contact EE Customer Service or a technical support team without making a phone call? I am currently in Iran, so making an international call is difficult for me.
I would like someone to check my EE account and specifically verify whether incoming SMS while roaming in Iran is fully provisioned on my line, and whether my SMS/roaming profile needs to be refreshed or reset.
I can receive SMS messages from EE itself, including the welcome message, but I cannot receive SMS from any other sender, including verification codes from WhatsApp and Telegram.
Is there an online chat, secure message service, email, or any other way I can have this checked without calling?
Ali_A
Hi @Elyas6740
Are you on Pay monthly or Pay as you go (Pre-Pay)?
Have you used the SIM card in the UK to make phone calls before you have taken it to Iran?
Ali
It is a Pay As You Go (Pre-Pay) EE SIM. I purchased this EE SIM as an international SIM from a retailer in Iran. Some of my friends had previously purchased the same type of SIM and were able to use it without any problems.
I have never used this SIM in the UK before bringing it to Iran. This was a brand-new, unused SIM when I purchased it.
Currently, the SIM has network coverage on my phone in Iran, and I receive all SMS messages sent by EE, including the initial welcome SMS. However, I cannot receive SMS messages from other senders, including verification codes from Telegram, WhatsApp and other services.
The main reason I purchased this SIM was specifically to receive SMS verification codes for different services. I don’t need mobile data or outgoing SMS.
Could you please advise whether the fact that I never used the SIM in the UK before bringing it to Iran could be causing this issue, and whether there is anything that can be done remotely to fully activate/provision the SIM for receiving SMS while roaming in Iran?
Ali_A
@Elyas6740
Ali
To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
Is there any way to check whether my PAYG SIM was previously activated on the EE UK network? I purchased it as a brand-new SIM from a retailer in Iran, and I am not sure whether it had already been activated in the UK before it was sold to me.
I currently have network coverage in Iran and I can receive SMS messages from EE, but I cannot receive SMS from other senders. Can you check from your side whether the SIM has ever completed its initial activation on the EE UK network?
Can you confirm whether topping up £5 has anything to do with the initial PAYG activation, or is the first call/SMS/data usage on the UK EE network the only requirement?
