23-09-2024 08:36 AM
I am having similar trouble whilst in Denmark;
Roaming Active - Via roaming abroad add-on
No call diversion active.
I cannot receive calls whilst I am in Denmark. Its an english message coming through saying i am unavailable so its an EE problem, not the local network (which would be Danish).
iPhone 13 pro
23-09-2024 03:32 PM
I have got it onto manual selection. I will go through the options available and see if that sorts the issue. Thank you for your help - it may not be the end, however!
23-09-2024 03:36 PM
In the meantime, FYI - you have a short time after posting to edit, by using the drop-down arrow in the top-right of each post.
This negates the need for multiple short replies.
25-09-2024 02:25 PM
The problem persists. No matter which network I use, every caller gets "this number isnt available at the moment, please try again later", if they are calling me over the network. I have to use Whatsapp or other apps to accept phone calls
25-09-2024 03:18 PM
