Raoming
Greavesy89
Currently in Turkey. Can't access any network. I have upped my spend cap. Added roaming to my plan. Can't get hold of ee as they only take calls and have no live chat. Currently up **bleep** creek without a paddle as the bank have frozen my card and need to contact them Again can only call them which I Currently cannot do. Any ideas???
1 ACCEPTED SOLUTION
@Greavesy89 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
