Receiving txt abroad
Carlf2
Hi
I’m in Barbados and I can’t receive calls or txt, I haven’t spoken to EE about being abroad and I now cant call them or txt them, I’m not the most tech savvy person, was wondering if anybody could help or point me in the right direction
thanks
9 REPLIES 9
Katie_B
Hi @Carlf2
Welcome to the community.
I hope you're having a great time in Barbados.
Did you activate Roaming before leaving the UK?
Call and text rates for Barbados can also be found by visiting our Roaming Tool
Katie
@Carlf2 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Carlf2
Hi Katie
I didn’t activate it I turned it off actually (not good) I’ve got it on now but I need to do things that require a txt and can’t
I’ll have a look at the roaming tool thank you so much
I was pay as you go but I now pay monthly not sure what that makes me now, I’ve had the number for years so yes I've used the number
much appreciated I’ll look into what you’ve said thank you
When was your SIM moved to PAYG? It takes 30 days notice to cancel a contract & before it is moved to PAYG. Had that change taken place while abroad you can't now use it at all while abroad. To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
quite a few months ago, approx 4 or 5, should have spoken to EE but it was such short notice
& that was while you were in UK for at least 30 days more?
In which case you are back to having not activated the roaming ability while in UK. You can't activate it while abroad except by calling EE.
Carlf2
Right I get you, I’ve tried calling EE with the number you provided but just keeps cutting me off
this is turning into a nightmare
really appreciate your help
If you have travelled abroad with roaming not being enabled, your phone will not have access to foreign networks. Making or receiving calls, sending or receiving text messages, and using mobile data - requires a mobile network connection which your phone doesn't have.
This is why you need to make contact via another means.
