Contacting ee while abroad
lordsargent
No service on my ee sim while abroad can’t call ee or anyone only have mobile data on a French sim
@lordsargent : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Northerner
Hi @lordsargent
Use Skype over wifi and the number in my signature.
