on 31-01-2024 02:51 PM
Can I use my PAYG Everything Pack allowances in Spain (Canaray Islands) when I go on holiday this weekend?
I read in another thread that: "On PAYG there are charges for using your pack allowances in the EU of either £2.50 / day or £10 / week," but I don't really understand what that means...
Does this mean that in order to use the allowances I have already paid for, I have to pay a further £17.50, as I'm going for 10 day?
I don't really understand "roaming" Do I have to allow (pay for) raoming to be able to use my phone on WiFi or 3G/4G?
I'm hoping the hotel's WiFi is good enough fr what I need, but just checking in case I need to use my phone (ie 3G/4G).
Thanks so much
Solved! Go to Solution.
on 31-01-2024 03:47 PM
EE is a UK network operator, but roaming means using your phone on foreign networks - in this case, the Spanish ones. Roaming provides you with mobile network coverage abroad, whereas WiFi is just a connection between a mobile device and broadband router - this is completely independent of the mobile network.
The charge you mention, is for the use of your UK allowances on these foreign networks.
on 31-01-2024 02:46 PM
Hi, I've just found this thread as I'm trying to find out if I can use my PAYG Everything Pack allowances in Spain when I go on holiday this weekend.
From the reply: "On PAYG there are charges for using your pack allowances in the EU of either £2.50 / day or £10 / week," does this mean in order to use the allowances I have paid for, I have to pay this? I'm going for 10 days.
Thanks so much
on 31-01-2024 03:08 PM
Hi @HelenUK,
To use your pay as you go pack's inclusive calls, texts and data, you'll need to purchase an EU roaming daily or weekly add-on.
Please see Pay As You Go Charges for Roaming in the EU | Help | EE for more details.
Hope this helps.
on 31-01-2024 04:08 PM
thank you for explaining it so clearly 😊
on 31-01-2024 04:16 PM
Thanks so much James, If I buy the roaming package will my normal PAYG package be frozen or is that what I'm using if I choose the roaming option?
on 31-01-2024 04:40 PM
The Roaming Pass allows you to use your UK pack allowances in Spain, @HelenUK 🙂
on 03-02-2024 03:58 PM
Thanks so much 😊
