on 10-10-2024 06:21 AM
Hi i am trying to make a call to the uk from india. What are my best options
on 10-10-2024 06:29 AM
@Farhaasherii : Possibly getting an Indian SIM.
on 10-10-2024 08:16 AM
For the cheapest per-minute rate on an outgoing call, an Indian SIM may well be cheaper.
If you're looking to make a few calls, a 60minute roaming bundle might work out cheaper and would be more convenient. Same goes for receiving calls, where callers dial your UK number as normal.
Prices are available at https://ee.co.uk/help/mobile/roaming/roaming-costs including links to add-ons.
on 10-10-2024 10:34 AM
Outside the EU, you cannot use your usual UK allowances there but will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/india.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
