Connectivity in Egypt
Nicnocstur
I'm in Egypt - I arrived this morning.  I have no connectivity at all. I've tried everything - turning airplane mode on and off, turning my iPhone on and off, selecting network.  Nothing is working and I can't get hold of EE as need connectivity to do that!  Any ideas gratefully received
1 ACCEPTED SOLUTION
