No Signal or Roaming Connection in Lebanon
Jihan1
I am trying to connect rooming in lebanon I have a spend cap £20 but there is no signal and there is no message with the link been sent to connect as promised on EE APP
@Jihan1 : Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto.
Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before leaving to go abroad?
If you are on contract, did you activate roaming on your EE a/c before leaving UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise if you are on contract you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. using a web-calling app over WiFi.
