Roaming in Australia
Kaye8
I have been in Australia a week, I bought the roaming pass. I am on contract. But it won’t work?
@Kaye8 : Has it worked at all during past week?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
6 REPLIES 6
I have the same problem also in Oz at the moment. I did roaming before I left.
I have done all the above, have an EE contract.
what is an account level one to enable international roaming?
Thank you, I am on contract and did everything.
Also downloaded Skype but needed text to confirm a code of verification, which I can’t get.
Sent from Outlook for iOS<>
Duplicate posts in other threads have been merged.
You've not answered whether you have been able to use your phone abroad previously? Or has it worked in the past, but stopped subsequently?
Kaye8
I have not used my phone abroad before and went to an EE shop before I left to find out what to do.
In which case - the advice posted by Xrayspex on 05/10 @ 6.25pm remains the question...
