11-09-2026 07:09 AM
Hi I’m not able to receive calls to my mobile in turkey I have a roaming package which is live, is it a setting issue?
11-09-2026 12:33 PM
Thanks for letting me know @Andy465,
It does sound off that you're able to use your calls but not your texts.
Are you able to access your internet?
A good option to try would be to do a manual network selection.
Try selecting:
Chris S
11-09-2026 08:05 AM
@Andy465 Can you make out going calls ok ? If you can have you tried restarting the device and or a manual network search to connect to a different network?
11-09-2026 08:08 AM
Hi @Andy465,
I hope you're having a great time in Turkey so far.
Could you try texting 'ROAMING' to 150 please? Just to check that you have the correct roaming option on your account.
If you have, usually a simple restart will get things sorted for you.
Could you try restarting your phone too please?
Chris S
11-09-2026 10:30 AM - last edited on 11-09-2026 11:35 AM by Leanne_T
Hi Chris
I can text but calls are not working I’ve restarted my phone but no joy.
Andy *****
[mod edit: removed personal details]
11-09-2026 12:33 PM
Try selecting:
Chris S
