Inclusive Extra Inclusive Extra ROAM ABROAD Pass
TEMENORGE
Valued Contributor
Valued Contributor
I want to just add it and be able to use my Internet in USA
1 ACCEPTED SOLUTION
Peter_W
Thanks for giving that a try @TEMENORGE.
If you have access to the app, can you select Manage Add-ons > Inclusive Extras > Manage Inclusive Extra?
It should let you view and change this here.
If you still continue to struggle from there, you can reach out to our team from any network abroad on +44 7953 966 250, or you can also call from a service like Skype on +44 800 079 8586.
Peter
26 REPLIES 26
Katie_J
Hi @TEMENORGE
Thanks for coming here.
Are you currently abroad or in the UK?
Katie
TEMENORGE
Valued Contributor
Valued Contributor
Currently abroad
Katie_J
Thanks for confirming @TEMENORGE
Did you activate roaming before leaving the UK by texting ROAMING to 150?
When you landed in the United States did you receive a welcome text?
Speak soon,
Katie
TEMENORGE
Valued Contributor
Valued Contributor
Yes I did
I was in US till 2nd April and just returned on 22nd and did text but
unfortunately my Inclusive Extra which allowed me to use the data I had
been using monthly before doesn't work. I was forced to pay 5 pounds for
just 24 hour
Katie_J
Hi @TEMENORGE
Does the Roaming Pass show active within your EE account online?
Is your plan a Full Works plan?
Katie
TEMENORGE
Valued Contributor
Valued Contributor
Currently in USA
TEMENORGE
Valued Contributor
Valued Contributor
It showed active for EE and also I was able to use the Internet yesterday because I paid the £5 for 24 hours but I used to have it monthly as part of my plan . But it just disappeared in the 20 days I left and returned
TEMENORGE
Valued Contributor
Valued Contributor
TEMENORGE
Valued Contributor
Valued Contributor
Yes , full works plan
