SIM card not used for 90 days
smanthc
Hello  my dad hasn't used his basic, non smart phone for over 3 months.  The SIM is now saying registration failed.  How can I reactive the SIM please?
@smanthc : Sounds like your PAYG SIM has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Sorry but this is not completely clear to understand and I've read it a few times now.
In your first paragraph you state 'EE PAYG SIMs are deactivated after 6 months of non-use'' - 'non-use' being the 2 words that I'm calling attention to here because in your next paragraph you state that using your minutes, text or data from your pack would not qualify.  'Non-use' needs to be changed or removed. I'm not sure which because I don't understand what is trying to be conveyed.
Can someone please re-type this and make it clearer to understand.
@BubZ1 : The non-use mentioned in the 2nd sentence of 2nd para is referring to non-use of any chargeable actions which is introduced in the 1st sentence of that para & further defined fully in the 3rd. para.
I'm not trying to write a legal doc. here but just a chatty explanation of EE's hibernation policy.
If you like, replace the "non-use" you are querying by "non-chargeable use".
