on 20-03-2023 12:10 PM
I want to remove parental control to my device and I'm having difficults
Solved! Go to Solution.
on 20-03-2023 12:41 PM
@Magnon1 , if you are near an EE store and have ID, you could go in there and they should be able to sort this out for you.
I would have thought speaking to customer service, they should be able to change parental control for you.
on 20-03-2023 12:17 PM
Hi @Magnon1
You can change your content settings on your EE app.
on 20-03-2023 12:20 PM
I tried but I couldn't, could you inform the fields? I already have a registered card.
on 20-03-2023 12:25 PM
@Magnon1 , if you cannot do this yourself, you will have to ring customer service to get this changed.
Are you on a monthly contract or pay as you go? If on pay as you go, I believe you will have to ring customer service to do this, but with a monthly contract you should be able to change the settings either via the EE app or by logging into your account via the website.
on 20-03-2023 12:37 PM
Hi @Schockwave
My plan is pay as you go, but impossible make this by phone, at the end of the call it says they are having technical problems.
But ok, thanks
