Overseas top up numbers not working
anita75
Good morning
from USA I am trying to add extra credit to my phone so I can call uk numbers
it is not connecting to any of the numbers eg 360 or 150
thanks in advance
Northerner
Hi @anita75
Was the PAYG sim activated in the UK.
When was the last time you made a chargeable call or text.
Does your phone show a connection to any US networks? Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
