I cant top-up my phone and cant recieve texts.
Hadyahfaroqy01
Hi everyone, my phone isn't receiving texts and I can't top-up my phone. I think EE has given my phone number to someone else as I can't call,text or recieve messages! What's the point of even having a phone if you can't do any of those!!
6 REPLIES 6
@Hadyahfaroqy01 : Where are you? When did you last use that PAYG SIM?
I'm located in the UK and I haven't used my PAYG sim card at all.
How long have you not used it? When did you get it?
I have never used Mobile data or credit and i got my SIM card in December 2022
If you’ve never used it it might now mean the number is dead as not used, you might need a new sim
Your PAYG SIM has gone into hibernation & then been completely deactivated due such a long period of non-use.
EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then had a further 3 months period of grace to call EE to reactivate it before it is lost completely.
