New ipad
Sharonj11
I’ve bought my son iPad as an add on for his Xmas . Is it ok not to activate until then??
1 ACCEPTED SOLUTION
Owen_2k4
Hello,
The iPad should be fine until Christmas, if you have a SIM card you will need to activate you will be able to do so separately from the iPad.
Hope this helps!
Thanks and have a great day!
If I have helped please mark my reply as helpful!
Device History: iPhone 3Gs, iPhone 4, iPhone 4s, iPhone 5s, iPhone 6s, Samsung Galaxy S8+, iPhone X, iPhone 12 Pro Max, iPhone 14 Pro (Current)
7 REPLIES 7
Owen_2k4
Hello,
Hope this helps!
Sharonj11
Hi I’m new to this and hopefully someone can tell me why I got sim to activate and number when I bought an iPad as an add on ?
and do I activate it ?
Sharonj11
Thank you for the help 🤗
No worries, I hope you have a great Christmas.
Hello, just saw the reply.
With the iPad you will have a SIM card which will allow the iPad to connect to the EE network to use mobile data when there is no WiFi connection. Hope this helps.
James_B
EE Community Manager
Hi @Sharonj11,
The SIM will be for your iPad's mobile data plan. It should be pre-activated and ready to use.
@Sharonj11   Because you purchased an iPad that has a contract. You’ll be billed before you even switch the iPad on.    Your under a 24 month contract with that iPad and you’ll get a set allowance of data per month,  just like you do with your phone.
