Secondary frequency for certain speakers at 2.5 ghz
Coutsofmar
Anyone having problems turning SONOS speakers in a wireless group
@Coutsofmar   If your speakers are set up and running independently then you should have no issues setting them up to work together as they should already be using 2.5Ghz.      Is your device connected to 2.5Ghz that you’re setting this up with.   Have you tried login in to your router as admin and turning off 5Ghz to set this up and then turning 5Ghz back on ?   What router are you using ?
Coutsofmar
Thank you I will try through the router.
