Glitchy pixel 6 pro?
Phil_stubbs
Anybody else pixel 6 pro a bit of a brick? Mine crashes constantly, connectivity is appalling...the page to post this message took over a minute to load on my "5G" connection. Just a bit disappointed and over it all.
6 REPLIES 6
Northerner
Hi @Phil_stubbs
Try backing up and then factory resetting.
As for 5G check for issues locally here:
https://coverage.ee.co.uk/coverage/ee
Hey Northerner. I've tried the factory reset a few times in the two months I've had the handset. No luck yet and tbh shouldn't be the workaround to a working handset.
I'm in London so not 5g coverage should be ok. Maybe my house is in a blackspot..there are rooms where I get very limited connectivity. Never been a problem in the past though on other networks I'm just disappointed with phone and the connectivity in general. For the cost ( twice my previous bill) I expect something that worked and didn't need to be mollycoddled to function in an acceptable manner.
James_B
EE Community Manager
Hi @Phil_stubbs,
Do you have access to WiFi at home?
Hi James. I do yes. I pay for unlimited data though so kinda expect that to work.
James_B
Hi @Phil_stubbs,
If there are some rooms in your house where mobile signal isn't available, I'd recommend connecting to your WiFi network.
Hi James. That's what I'm having to do. My dissatisfaction comes from the fact this is the first network and handset I've ever had to do this with. All whilst having the pleasure of paying double the cost from my previous network. It's just unpalatable that a work around is try factor resets (dont work) or use wi-fi. There should not need to be a work around
