20-06-2023 06:11 PM
i want to apply for a sim only contract what should i fill in under employment status if i am not employed.... if i select other then it is still asking for a start date.
21-06-2023 08:05 AM
Hi @kkash
Thanks for coming here.
If there is no option for currently unemployed, can you add the start date of how long you have been unemployed, does this work for you?
Thanks 🙂
13-12-2023 04:37 PM
I have the same problem. I tried to fill in the employment status but I just ended up going round in circles again and again! There is no way for someone with a disability to fill in a simple form with EE!
13-12-2023 04:41 PM
I don't even know whether to expect a reply or not, but let it be known that I did try and it is not my fault that I failed.
13-12-2023 05:55 PM
