Re: Unable to generate EE Perk codes for NHS discount
Emwils
Hi I am having the same problem, been trying to change my contact but cant get a nhs code. Can you help? Thanks
1 ACCEPTED SOLUTION
Michael_D
Thanks for confirming @Emwils
I've sent you over a private message to help with this.
Michael
Michael_D
Hi @Emwils
When you say you can't get a code, are you able to login to your Perk account and it says that you have codes available but won't generate one, or are you unable to login?
Michael
As above it says unable to retrieve codes once I click activate code.
Michael_D
Michael
