06-11-2022 09:25 AM
Why can I not make any calls or send txts?
06-11-2022 10:25 AM
Hi @Sean5369
When was the last time you made a chargeable call or text?
What device do you have and did you get it from EE?
Are you innthe UK?
06-11-2022 10:32 AM
06-11-2022 11:18 AM
Hi @Sean5369
Thanks for coming here.
Have you tried restarting your phone?
Aare you in the UK?
06-11-2022 11:23 AM
Are you on Wi-Fi now?
Is Wi-Fi calling still enabled and set as the preferred option?
Have you tried briefly going into airplane mode and then re-enabling the radios?
06-11-2022 11:24 AM
06-11-2022 11:26 AM
Hi @Sean5369
If there a network problem in your area, you can register for updates on the EE Coverage & Network Status Checker.
The network team will text or email you when there is an update.
06-11-2022 11:27 AM
06-11-2022 11:28 AM
No problem @Sean5369
06-11-2022 11:32 AM
