on 05-11-2022 02:26 PM
I’m trying to ring numbers from UAE to uk and all numbers are barred. How do i fix this please?
on 05-11-2022 02:35 PM
Where are you ringing from?
on 05-11-2022 02:43 PM
Did you enable roaming before leaving for the UAE?
on 05-11-2022 03:06 PM
Hi @Jellytot
Thanks for coming here.
If you have a pay monthly account, could you check your roaming status by logging into your My EE account online go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Call abroad, do they show as ticked?
Leanne 🙂
on 06-11-2022 11:28 AM
Unfortunately not… only just moved to EE the day I flew out on a pay as you go.
Can I still change the setting to access barring etc?
on 06-11-2022 11:29 AM
I’m on pay as you go and don’t have parental and data control options.
on 06-11-2022 12:09 PM
Did you use that PAYG SIM for making calls or texts in UK before you left to go abroad? EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
