Voicemail notification will not disappear even though there’s no message
Melads23
Hi, can anyone help.
I’ve getting voicemail notifications even though there’s no message.
I’ve done a soft reset.
I’ve had someone ring my phone, leave a message and I’ve listened to it and then deleted it and that didn’t work.
I’m not sure what else to try.
any help help please?
thanks
@Melads23 : Leave yourself a VM & then delete it. See if that clears it.
20 REPLIES 20
Thank for the advice.
it’s gone 😊🙏
I would've thought my post was the Solution, but it's your choice.
Hi, tbh I’m not sure if yours was the solution but I thanked you anyway. I think the actual solution was getting someone else to ring and leave an answering message, which I’d read on a different thread. I say this because, the last step I tried was that one and it didn’t work straight away so I posted on here. I then read yours and went to try it and the notification had already vanished. So I can only presume it was the ‘get someone to ring me and leave an answering message’ that did the trick.
Leanne_T
Thanks for coming back and letting us know @Melads23
Leanne 🙂
LBKB
I am also having the same problem
@LBKB : Did you try my suggestion?
LBKB
I have tried ringing from another phone and then deleting the voicemail, that didn’t work.
I’ve read your thread and just to clarify, did you get someone else to ring and leave a voice message and then delete it once you’ve listened to it till the end? This worked for me but didn’t happens straight away.
good luck
