URGENT: NOT RECIEVING TEXTS ABROAD
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 03:24 PM
Hello,
I am currently in Morocco and I don't receive my texts and calls from here. I tried to add a new add-on, allowing me to send texts but It doesn't work for sending or receiving.
I can't contact EE support as my SIM card doesn't work from here and its urgent please
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 04:34 PM - edited 26-06-2024 05:28 PM
@aliabenj : What add-on did you try to buy?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 04:49 PM
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. Does your phone show a connection to any Moroccan networks?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 04:52 PM
Yes, it gets connectes for 10 seconds and then show no signal again
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 04:57 PM
Hi, thanks for the reply.
Yes, I have been using the same SIM card since 2018 and no problem with it.
I think the roaming is activated as my phone connects to a local service but for only 10 seconds and then it shows no signal again.
I activated the '100 texts' add-on. I tried sending texts and doesn't work too. I cannot send texts or receive them.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-06-2024 04:58 PM - edited 26-06-2024 04:59 PM
That sounds suspiciously like roaming is not enabled - the phone is attempting a connection but is being rejected. You could try a manual network search and check the behaviour is the same across all available networks, to be sure. If so, the advice in the previous post, re-phrased below, stands.
@aliabenj wrote:
Yes, I have been using the same SIM card since 2018 and no problem with it. nd texts or receive them.
Does "no problem with it" include usage abroad?
On PAYG, roaming is auto-enabled once your phone is used in the UK first.
