Urgent help for roaming abroad
Leely
I am in Vietnam and trying to get a roaming pass!
all of the solutions I’ve read in other forum posts don’t work.
phone rings dead via 150 , +44 800 9566000, +44 7953 966
no response on the text 150 when I text ROAMINGDATA
ZERO help on the app.
this is ridiculous being a line traveler and having rely on WiFi with no means of communication with EE.
any help please? Urgent.
thank you
Rach_H
Hi @Leely,
Welcome to the Community!
I'm so sorry to hear about the trouble you're having using your phone while you're away. Did you reach out to our team before you travelling to ensure that your phone was set up for Roaming?
Rach
Can you be more specific about what you've tried thus far? You may not have read all the potential fixes, but if you can explain what you have tried, there may be other options.
