16-09-2026 08:45 PM
Hi, I'm a pay monthly user with unlimited data. I'm trying to see if i have data allowance included when i go to Denmark later this year. When i go to /plans-subscriptions/mobile/roaming and enter Denmark it comes up with
"Roam like home
Your current plan allows you to use your phone abroad like you would at home, at no extra cost.
If you go over your plan allowances, standard roaming charges will apply."
and texting 150 with ROAMING then DENMARK with
"Okay, your settings are correct to roam in DENMARK
You'll have access to your UK plan allowances for free while your in the EU zone."
Is this confirmation that i will have data when in Denmark given potential costs if not?
16-09-2026 09:57 PM
Yes, subject to that you may use up to 50GB per billing month of your data while roaming.
