How nan I get urgent help from EE whilst abroad and my calls are somehow blocke
PAIA
How can I get urgent help from EE whilst abroad in Australia.  Both my son’s and my calls are somehow blocked despite me having arranged a contact to cover calls abroad. He URGENTLY needs to call someone but even EE calling is blocked
@PAIA : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
DJW-20
Worth noting to make sure your spend cap isn't too low
I am NOT an EE staff member, but I'm still happy to help! I cannot access your accounts
24m EE essentials Max
BT 900mbts FTTP
