UK IP Address While Roaming
JosephDuffy
I'm current roaming but my IP address shows as a UK IP address owned by EE when I check it on various IP-checking websites.
This is a bit of a pain when accessing local websites that assume location by IP address, but it also seems to be causing the data to be very slow. Even on 4g I top out around 4mbps and have pings of 200ms+ to the UK and 300ms+ to a server that is only a few miles away.
All of this makes me think that my mobile data traffic is being proxied through an EE server in the UK, leading to a degraded service. Is this the case? If so, can I opt of this?
1 ACCEPTED SOLUTION
Hi @JosephDuffy
Call & data routing whilst roaming can be complex, in-country voice calls can be routed locally but mobile data will use EE's core network.
This is not something user-selectable.
7 REPLIES 7
@JosephDuffy  Your using a roaming network and the speed you are getting will depend on what agreement EE and that roaming network have with each other.  Have you just tried restarting the device?
I've restarted the device, tried manually selecting networks to test different carriers, and tried using automatic.
I can understand having a slower speed due to agreements with the local carriers (plus no 5g, general variability meaning I just got unlucky, etc.). Perhaps the same could explain the higher than expected pings too.
Even allowing for variance getting a better ping to UK servers compared to ones less than 10 miles away and always getting a UK EE IP address points to the traffic being routed through the UK?
@JosephDuffy  Your phone will always been connected through to EE as EE is uk based.  Even if you call a local number it’ll get routed through EE before going through,   Your usage have to be registered against your account.
Hi @JosephDuffy
It makes sense too for when you are trying to reach country-restricted content from a UK phone wherever it may be located.
Thank you for confirming. I wish it were possible to opt out of this so I don't have a 300ms latency on every request, but I understand the reasoning.
This is a tradeoff that for me falls on the side being less useful. Lots of home routers support being a VPN server so it's easy (and free) to have access to a secure UK VPN, but accessing an IP in the country you're roaming in requires access to a local internet connection or a 3rd party VPN.
